Mk3 golf AHU estate.
Full car with key. Engine has done 129000 and runs brilliantly!
Has sustained light front end damage, NO DAMAGE TO THE ENGINE, is recorded as CAT C.
I bought two and now this one is surplus to my needs!
Car is located in Stagsden MK43 region of Bedford.
Car will need to be trailered away due to front knock and no tax.
Looking for £450 ovno
(Can put pics up once I pop into the unit!)
Discussion Starter #2
No one TDIing that the moment??? Going on ebay next week I think.
£400 anyone :*
If it made it easier I could potentially strip it for the buyer.....however I'd rather they took the whole car so nothing was missing.
I'll be getting pics over the weekend
No history with the car as I didn't receive any when I purchased it.
While the engine was out I would give it a through going over and change most things....clutch, belts, just because of access it makes sense! (Which I will do on the other one I am using). So history wasn't too much of a concern, I was looking for a clean, low(ish) mileage engine.
I can tell you it throws no fault codes, has no lights on the dash and drives really nicely.
If anyone wants to drive it it's located on a farm estate so it's almost a private road for test drives....I: this is also better then the other one I have as the shell is heavier, meaning you'll get a bit more back in scrap!
