I've just bought a single seat from a VW mobility conversion (correct Fabric :)) with legs, but they have been welded into some larger rails :(.
I'm hoping to make it Quick Release with the correct legs to work with the notched railings. I also need two short lengths of the railing to mountain the seat next to the sliding door.
Thanks Guys T: - rapid response!
Reimoboy - that looks pretty much like what I have in mind. Might go for the flush rails if possible though.
Is your seat made by Cogent of Swansea? Is there any chance you could get a close up of where the legs fit to the seat? Mine has two rectangular rails that run across the front and rear of the seat, and for which I have 8 rectangular nuts with bolts.
Where can I source the legs that you've got?
See you at CamperJam!:ILU:
Got a feeling your seat base may be different from looking at that link. Difficult to tell.
Can you get a shot of the underside, and from the side, square on, if that makes sense, if its not too much to ask.;)
