Possibly the easiest way is to slide out one of the others from behind the bumper (should be really easy with one of the outer ones) and look at the part number on it - or even easier phone up TPS with your VIN and ask for part number and availability. But don't even think about actually buying it there as they are near enough £100 each.
Then go onto Ebay and find the correct part - typically around £15 shipped.
Colour coding them yourself (if you care about that) is easy enough with a rattle can, but don't put the coats on too thick - if you bridge the gap around the outside it will stop it working.
