Hmmmm... i thought that whole unit bolted to the door? :confused: once i pull it out I gotta go all the way! otherwise I have no windows:eek:
hi mate i cant see the pics in your link- is the bracket the one in the 5th pic down on here
http://www.vwt4forum.co.uk/showthread.php?t=1505&page=2
if so then it helps to spread the torque from the motor over a larger area making it more stable and less flex
if you look at the 6th pic you sould be able to work out where it goes from the position of the screws T:
it reinforces the door skin so it does n't buckle when using the window
you've got to fit it mate
T:T:T:
3DR RALLY SLAG that was a pick of a tailgate:confused:
topsparky, cheers fella understand now, do you have any gen on fitting OEM leccy windows im havin a mare! we could PM if you like
i've just fitted gen ones to mine give us a pm with you mob number
