1 - 20 of 57 Posts
I have just discovered what VCDS is while stumbling into MFSW envy.. so now I want one.
So it seems that there are 2 or 3 different models of OEM MFSWs & all sellers say something like " fits transporters" or "fits T5.1" but then also say " make sure it is compatible before buying". How can I find out which is compatible? To be more precise is this type compatible with any T5.1?
Then it seems straight forward enough to fit one apart from the coding. Is there any kind soul in Brum or close enough to help me code it if I get one ? I can pay in home made craft cider if that's your poison.. or cash.
Tog
That looks to have been taken from a T5 so fitment shouldn't be an issue.
However, be worth speaking to Paul @ Retrofits as he will supply, install and code a new steering wheel to your spec. Will cost a little more but you can get a custom wheel and a job done properly. (y) He's in Hinckley so not a million miles away from you.
So I fitted a MFSW from a mk6 polo onto my 2013 T5.1. It works a treat and worked without coding which I believe is because I have the highline model.
Having purchased a mk7 golf steering wheel all my research and comments from this forum and others is that it won't work because these recent wheels communicate with Linbus whereas our older vans are canbus.
The first wheel I bought had cruise control on it and that seems to be the key indicator that it won't work. It's still sat in my garage...
So my recommendation is pick a mk6 wheel and you'll be fine. The one in the link should work.
There's a couple of good fitting videos on youtube if you haven't seen them before.
Special Rapporteur
No - that's not correct. The facelift onwards use LINbus as well as CANbus. The MFSW on a facelift is implemented via LINbus, which is built into the main body control module. In addition to the MFSW, the facelift uses LINbus for door control units (both front and rear), roof control and also in the factory alarm system.
My limited understanding of the pre-facelift is that the BCM does not incorporate LINbus, so you need a separate module to implement it (and that module talks to the rest of the vehicle via CANbus). VW actually called this a "single wire data bus" on the pre-facelift, so it may have been an early interpretation of LINbus, rather than a fully compliant implementation.
Nice one Pduk.. that sound good to me.
... thanks for all your replies. I'm glad I asked as that sounds like another can of worms
I really like to do things myself but sometimes it's best left to others, this might be one of those times.
Paul @ Retrofit was helpful & his prices seem reasonable.
I was weighing up having my mfsw fitted by either Paul or T5 Upgrades who are based in Wales. Met T5 Upgrades at Busfest and they agreed to fit it while I was at the show 😁
It is all a bit frustrating for me as I am on a tight time schedule to get everything I want done but with more time to learn I could save myself a small fortune... no hum.
Discussion Starter #12
Why the rush ? I am heading off to France as soon as our house sale is completed (hence the LHD).. which is soon enough (fingers crossed) & I do not fancy talking tech in very poor French. That is assuming that I can find anyone who does all this funky stuff down there. I have so many plates spinning that I wake up at 3am thinking of what needs doing & not just the nice things to do with my new van.. for example this week I had to learn all about euro8 tractor attachments so I could send a pallet fork attachment to my Father-In-common Law in time for him to unload my palletted workshop. I was then side tracked by MFSWs !
B&T; What was wrong with the one you bought ? I almost bought one today, I'm glad I was stalled ..
How do I tell if mine is LINbus or CADbus .. I guess more Googling
I bought one with cruise control on 😆 .
I'm still gonna use it cuz my original wheel looks pants and just buy blanks for the buttons .....need to still find an airbag to suit mind you .
my foolproof way of doing this is just remove your airbag and take a picture of what you see, then by a wheel that looks the same, but has MFSW and or paddles on.
some have a control module in the middle, and some don't.
you can get the right wheel from a lot of different VW's, passat, golf, tiguan etc i'm sure
I'm not sure about the newer wheels with cruise control on them, I was put off this by the fact you have to buy a new airbag, and a normal cruise kit for t5/t5.1 is cheap enough to just have it on the stalk
Discussion Starter #15
Ah bxxxks.. I forgot to follow up on that LINbus/ CANbus detail before purchasing one off Ebay. Am I going to regret not going for the £290 supply & fit quote ?
What can you see without the airbag if the connections are below the steering column? The " new" MFSW looks identical with the airbag in place (apart from the buttons) & it came off a T5.1 but that may mean nothing.
(I am going to try really hard to forget you have mentioned cheap Cruise Control kit.. I need no more temptations right now)
have a look at these 2 ebay ads here and here notice the difference? mine is the type without the control module in the middle. I was led to believe that older vehicles used these but that can't be true as my brother has a 64 plate amarok and it has the control module in the middle.
and here you go, link to the cruise kit
This is the type I fitted to my 2013 Highline. With the addition of the two wires it worked out of the box no coding required. I didn't pay £295 for it though, more like £225 from memory. I'd have liked the snazzy GTI/Rline wheel with the round bag but they are serious money, too many other things to spend van money on!
Having researched for ages and consulted with others who have made the change, the key message was look for a MK6 VW wheel rather than MK7 and stay away from ones with cruise buttons on the wheel. It probably took a couple of hours to fit, but then I went slow as working in close proximity to airbags is a little uncomfortable.
Discussion Starter #18
Please bear with me as I can be slow to undersrand things ..
I don't understand what looking under my air bag will show me... I do not expect to find any wires there at all.. ok so maybe something for the airbag.
I thought the problem is me not knowing what system I have ... then once I find that out then I buy a MFSW to suit.. No?
Many Thanks for helping
Discussion Starter #20
Doh!... now I see, it's not just the wiring. So, if I match up the style of wheel the electronics will follow ?
Thanks for bearing with me Fenwick458
1 - 20 of 57 Posts
