Am I right in thinking that a Multivan seat (bed) will not fold flat in a Caravelle due the rear interior panel on the o/s of the van?
No mate they fit perfectly. The rear shelf is slightly narrower than the seat section of the bed to accommodate the wider panels at the rear.
The seat pulls forward first then folds backwards so the seat doesn't need to go past the wider panel.
Thanks NealT:
You may need to change the "u" clips that the rear seat back clips into if you have the shorter ones.
They are available from VW though for about £17/pair.
Other than that, everything else fits, seatbelts are the same too so will fit straight into the MV seat receivers.
