Previously; stevemadbiker
Hi Guys
Dose anyone know the difference in length between the long mushroom bolt and the standard one ??
Also any ideas on the price
many thanks
steve
Hi
part number AZ 703 883 297 - A
just make sure that they order the 34mm bolts and they are £ 6.57 plus vat each
If you want the under floor plate with captive nut the part number is
703 883 281 £6.09 plus vat each
just make sure the parts guy know exactly what you have ordered
steve
AZ 703 883 297 - A is actually the shorter bolt. The 34mm bolt had a slightly different prefix. However, it is now a new part number anyway:
WHT775005871 This is the 34mm bolt. I have a set of 4 23mm (the standard size which are too short to go through a plywood floor too) which I will be listing on ebay soon.
