81 - 100 of 219 Posts
Discussion Starter #81
Would love to have etching done but I don't know anybody so probably have to settle for vinyl
Start the flooring today, can't wait
Discussion Starter #83
There's companies all over the uk, I'm sure one would be able to create whatever you want. Definitely worth looking into (y)
Would be alot better than a standard sticker setup that would look cheap I suppose
Discussion Starter #85
UPDATE
Well today's progress has been eventful but satisfying to say the least.
Started off by fitting the Autowrap Sound Deadening to the floor, was a bit of a mission when there's only 1 pair of hands hahaha, so sticky and if you don't watch yourself it easily splits.
Decided to do it lengthways to minimalist cuts. Looked really good when it was down.
177984
177985
177986
177987
Then it was onto the 6mm ply boarding. Again decided to go lengthways in order to minimalist cuts, the big one took alot of measuring but was worth it. Once all the boards were cut to suit the van I used a trick of the trade from Princess Yachts and dot and dabbed loads of Marine Dow all over the ridges of the Sound Deadening.
The ply boarding was then sat in place and using alot of weight found from in my garage I placed it all over the ply boarding in the van therefore pushing it into the Dow in order for it to seal overnight.
177988
177989
Tomorrow's it's onto the silver foil insulation and heated floor element, can't wait for that to go in.
Also lastnight I ordered my flooring, should be here Friday ready for installation, so excited
177990
And just for you guys this is what colour my units are going...
177991
More to follow tomorrow
Discussion Starter #86
UPDATE
Well this morning I am very happy with my progress, I've managed to fully insulate the floor in preparation for the flooring that turns up tomorrow, really took my time doing it in order to get it right without any loose ends or saggyness.
178020
178021
178022
178023
178024
Having finished the floor insulation it's now onto my modification which I feel is a huge Gamble, never seen it in a van before so time will only tell if it works or not hahaha.
178025
178026
178027
Now, even tho it's a heated floor and with my calculations it should work perfectly with what I have in mind, I am hoping it works well enough to carry the heat across the rest of the floor using the metal foil to transfer it, technically and logically it should work hahaha. I am putting a 12mm floor down tho 🤔
It came in one long roll but carefully splitting it and making two runs equally spaced apart shouldn't cause an issue with heat transfer.
Hope you guys like my work so far
Discussion Starter #91 (Edited)
UPDATE
Just another little update for today, refitted my front centre pod but accompanied with my new pair of Alpines to match those in the tailgate
178033
178034
178035
178036
Starting to get there but I feel the cab still needs something
Discussion Starter #93 (Edited)
I have mate but bugger me that will be expensive hahaha
UPDATE
Well made the first big mistake since I've started the build and it's down to ordering not enough kit hahaha. My bad.
So I started the day off realising that I didn't cut out the hole in my silver foil insulation for my rear blower motor to blow out hahaha, silly boy but all resolved now.
178062
178063
178064
178065
My side step as seen below will be getting painted black and having an inlay with the same wood flooring on the base. The slot you see at the top of the step will illuminate purple.
178066
Also painted my front step aluminium inlays so they match the rear when done
178067
Made a booboo and didn't order enough flooring, plenty of I didn't stagger the joins but it's how it's meant to be done, oh well. Await another delivery I suppose
Research shows that a leather (not alcantara) always has problems staying adhered to a plastic dash.....soooo :cry: .
Good progress still mate (y).
Discussion Starter #95
I'm thinking of dying the dash and doors black.
Not as much progress as I had wanted fella, my bad for miscounting how much I needed hahaha
Discussion Starter #96
UPDATE
Sorry there was no update yesterday after I had finished I was so tired I completely forgot.
But here we are and some more progress made.....
New door steps in black
178143
178144
Side window fitted, getting the old sealant off was a pain in the bum
178145
178146
178147
178148
178149
178150
That was yesterday and today I decided to rip out all the old rock wool and replace with my new silver foiled stuff
178151
178152
Discussion Starter #97
178153
And then it's onto the rear steps to match the fronts
178154
178155
And I have also made off my external hook up
178156
178157
178158
Will keep you posted this evening if I get anymore done
Discussion Starter #99
Cheers dude
UPDATE
Just wired in my underfloor heating ready for the side panel to go back in
178173
178174
178175
Just awaiting the Thermostat to turn up then it will be completed.
This is what I'm waiting for in the post
178176
And I finalised the position for my light switch
178177
178178
Not really much done today but I am awaiting lots of parts to arrive
More top work there mate (y)
How easy / difficult was it to get the window out? I'd love to replace my sliding doors static window with a slider.
Also...please tell me you're replacing the screws on the steps for black ones? My ocd spiking 😂
