Hi Kevr,
Thanks for the tips, I was considering the rockwool inside anyway and have just insulated my workshop roof so I went for it. Having listened before and after I'm convincedT:
I looked at Horace's build thread expecting some fantastic four 15" sub install after your post but I guess you went a far more sensible route and just got a sony box. Much easier if you have the room.
Some great stuff in your thread though, will be revisiting that on a few occasions. A:
Wullie, thanks for getting back. I do like that shape. The tapering looks good, and fits much better with the under dash shape. I might go this route myself if I make another How does it sound by the way? Any idea how low she goes?
My Progress, continuing from where I left off:
...Well kind of, I didn't get any pics of fitting the panels round the back but it was pretty straight forward.
Cut a strip of mdf 340mm wide and then cut each piece to the required dimensions and angles (I will get that template soon people I
I then used plenty of glue and a brad nailer, always making sure everything is flush and square.
Cut the mounting hole and chamfer inside edge:
Ready to fit front panel to box:
The MDF is not great for screwing into so requires long screws with deep thread and must be well tapped and tightened gingerly.
Again, plenty of glue. MDF edges soak it up.
installing the driver:
PE foam tape should give a nice seal:
Test fitting:
The banana plugs and binding posts were, again, something I had lying around.
The fit is good!
A little on amp installation:
I though it best to cut the end of the power lead at an angle to aid its passage
I cut a slit in the black grommet and fed the wire through:
Which popped it out under the middle of the glove box...
...and the fed it under the carpet, round the wheel arch and along the top of the step to under the passenger seat
The amp is mounted on slats running crosswise, fixed to slats drilled to fit the seat bolts. the ground is taken to a ring terminal on a seat bolt.
Phono cables (currently far too long) and speaker wire runs from seat corner to under gear stick trim
In the engine bay again- the fused feed ready for connection:
BTW- Connect this to the POSITIVE terminal of your battery! What kind of idiot would connect it to the negative eh?
...I:
Back to sub:
Carpeting-
a flat surface, a lot of weight and some patience help.
And it's done!
Yeah I know my van needs cleaning...Rasp:
Initial test tone fiddling reveal that it's pretty strong down to around 37Hz, if a little lumpy. There's some cabin resonance around 100hz and I need to tweak my EQ a little.
My stupid head unit (KDX50BT) allows you to set sub crossover frequency up to 120Hz and then a separate high pass on the normal speakers. But the HPF seems to be around 300Hz and fixed!
Which means everything in between is a bit muted and needs boosting by EQ. Not ideal. If I turn the HPF off, the mid-bass gets too overblown and needs EQing down with the door speakers and sub competing for phase around a crossover point..:*
Half my reason for wanting a sub was to alleviate the door speakers from from the bass so they could produce cleaner mids.
But for now though my set up does that and sounds pretty good. Listening to music in my van is a whole new experience
Apologies for such a long and pic heavy post but I hope it might be of use to some people.
Any questions and I'll do my best to help.
