21 - 23 of 23 Posts
Discussion Starter · #23 · (Edited)
Been a while but managed to get some time in on the van.
First job was to fit the rear seatbelt. I got the upper seat belt mount from vw I think it was about £8.
Next up was to open up the panel and get some holes drilled for plug welding the seat belt mount in.
All welded up primed and seat belt fitted. When I had my rear windows fitted i had the inner & outer skins spot welded together.
The rear wheel arch looked a bit suspect.
So I got the grinder on it and this is what I was left with!
All cut out and primed
Welded up & seam sealed
Not a bad afternoons work. :)
21 - 23 of 23 Posts
