1 - 10 of 10 Posts
going from a 235/45/17 to a 215/60/17 . they fit a treat so loads of rubber for comfort now T:
might be useful for reference
wheels ET35 8J lowered by about 60mm on eibachs . full camper conversion and its heavy !
Any pics of the rear (tyres that is)?
ive only put one on at the moment as i wanted to be sure they fitted propperly . i have took it for a good spin , put the wheel under "load" and it does not rub . give me till mid next week and i will take a full on side picture with them both in view . they defo fit , and they are umber close on the inner wheel arches , but they do go T:
Reason I ask is the tyre combo you are looking at has the same rolling profile etc as the ones I am running and I am curious as to the rear arches and clearance etc as I am trying to convince the mrs that new rear springs are a good xmas prezzie!
http://www.willtheyfit.com/index.php?width=215&aspect=60&diameter=17&wheelwidth=8&offset=35&width2=225&aspect2=60&diameter2=16&wheelwidth2=7.5&offset2=42#content
they clear the arches on the rear . i tried .and we put a further 150kg iright on the back so i am sure it was on the stops . i can measure the distance fron the wheel centre to the arch if that helps ?
sc vw customs 1.9tdi convert
looking sweet mate....but are you sure you aint going to get any rub on the front under compression when on the road...
looks like that could be very close...:ILU:
Discussion Starter #10 (Edited)
Colese
i know they look close . i have put the one front wheel up on a 3" curb and jumped up and domw on the step and could not get it to touch . i also took it for a spin in an aggressive circle and no apparent rubbing . only realy way to tell i suppose is get the whole family in there with extra weights and see how it goes ..
i have also in my mind to jack it up if needed as to be honest i am going for comfort now more than looks .. its down on eibachs without rubber shimms so i can always add them back in if needed
will let you know how it all pans out T:
i drive like a old man anyway so i think the load under braking and dipping will be minimal
1 - 10 of 10 Posts
