Hello all, I'd appreciate some assistance as I'm at the limit of my technical ability with this one;
VW T5 2008 1.9L BRR engine.
Engine emissions light came on after the van stood still for 2 weeks (cheers COVID). This was accompanied by a huge loss of boost (like none) and the turbo isn't working at all. My N75 valve also went from mooing post shut-down to mooing constantly so the first thing I did was replace that (OEM part off ebay 1K0906627A), which stopped the mooing.
The loss of power and emissions light have remained.
I can't see any breaks/leaks in the pipes to/from the N75. When I take off the far right pipe I can feel suction when I put my finger over it. When I take all the other pipes off the N75 I can't feel a thing so, clearly, there is no suction going to the turbo to control the boost. I'm assuming the N75 is fine given that the problem started before I installed it and it's brand new.
Fault codes are P0299 (turbo underboost) and P0236 (turbo boost sensor A range/performance).
My thinking is that something is preventing the N75 from operating as it should and not sending anything to the actuator. When I carried out a freeze frame read I got a MAF reading of 0 (g/s) which seems wrong (not that I have a clue what I'm talking about). Could the MAF sensor be faulty and preventing the N75 from operating correctly?
Likewise, could the boost pressure sensor be a possible culprit?
I did wonder about the sticky vanes issue in the VNT, however when I move the actuator rod it feels smooth as silk and I can hear there's a good vacuum with air being pushed (or pulled, not sure) through the vent on the N75. I chucked some of that Wynns turbo cleaner in the tank for good measure, but I'm sure that was a waste of money.
Am I on the right tracks or has anyone got any other ideas?
TIA.
TIA.
