Hi everybody
I have a t4 1.9 td abl engine which before i change the clutch car wasnt run so well . Trying to test it all the parts like egr ,turbo and to the end change the kit of clutch but nothing special.
Again it dosnt show diference on running it slow down on the 5gear with new clutch.
The max speed today was 90 kmh on down the hill.The 1gear does not climb a midlle hill when i push the accelator it goes down like the pump cant take diesel and my t4 dont move
Hi Devi,
I take it your first language is not English so I'm struggling a bit to understand your problem so apologies in advance.
Have you checked the pump timing with a pin in the pump pulley whilst the engine is at TDC?
Also have you changed the fuel filter recently?
Hi Devi,
Thanks for suggestions friend.
Two weeks ago i changed the fuel filter, for the pump im not sure because the van start on in first key but the last thing i hope to find a good pump specialist to see it.
Thanks a lot
