I just bought a T4 2.5TDI (ACV) at a bargain but it seems to be underpowered.
I bought a VCDS and run a test. I would like help on how to sort the issues
the test results are as below
Wednesday,18,September,2019,13:02:19:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WV2ZZZ70Z3H029620 License Plate: KBF999H
Mileage: 155530km-96641mi Repair Order:
Chassis Type: 70 (7D - VW Transporter/Multivan (1996 > 2004))
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
VIN: WV2ZZZ70Z3H029620 Mileage: 155530km-96641miles
Address 01: Engine Labels: 074-906-018-ACV.lbl
Part No: 074 906 018 AL
Component: 2,5l R5 EDC 0000AG 3906
Coding: 00001
Shop #: WSC 00011
VCID: 60C87BC2E0D8E34FF9-4B18
WV2ZZZ70Z3H029620 VWZ1Z0B2112080
5 Faults Found
17946 - Fuel Shutoff Solenoid (N109)
P1538 - 35-10 - Open or Short to Ground - Intermittent
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
17656 - Start of Injection Timing Regulation
P1248 - 35-10 - Control Deviation - Intermittent
16885 - Vehicle Speed Sensor
P0501 - 35-00 - Implausible Signal
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 7D0 614 111 B
Component: ABS/EDS 5.3 D00
Shop #: BB 24258
VCID: 1B320C2E893E80976C-515A
Note: Excessive Comm Errors
Address 08: Auto HVAC Labels:
VCID: 55A65A16AC9A16E79A-FFFE
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 BL
Component: AIRBAG VW3 - V04
Coding: 16972
Shop #: WSC 02760
VCID: 74E0079244206FEF8D-4B32
No fault code found.
Address 17: Instruments Labels: 7D0-920-xxx-17.lbl
Part No: 7D0 920 802 Q
Component: T4-KOMBIINSTR. VDO V01
Coding: 01123
Shop #: WSC 19411
VCID: 316ECE86FBB21AC726-515A
1 Fault Found
01086 - Speedometer Sensor (G22)
06-10 - Signal too High - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00000
Shop #: WSC 02760
VCID: 70E80B82303853CF69-515A
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 00530
VCID: 7DF622B6776A2EA7F2-4B18
Address 35: Centr. Locks Labels: 7D0-959-800.lbl
Part No: 7D0 959 800 B
Component: Funksteuergerát 0001
Coding: 00001
Shop #: WSC 02737
VCID: 2C50DFF2DC90772F15-4B18
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 7D0 035 186 A
Component: Radio BNO 0006
Coding: 09401
Shop #: WSC 02760
VCID: 234234CEB14EB857A4-4B00
1 Fault Found
00856 - Radio Antenna
36-00 - Open Circuit
End-------------------------(Elapsed Time: 03:31)--------------------------
