Hy there to all of you,
For two years ago I bought our T5 second hand. But now blocked in P I have a serious problem.
Does this sound familiar to anyone:
P173400 and also U010300
Any suggestions?
This occurred after an empty battery, which was only one year old and after charging I had this problem.
Communication Device Font Mobile device Gadget Screenshot
Have you tried clearing the codes to see if they come back? A lot of codes can be logged when the battery goes flat but can be cleared once the battery is replaced / recharged.
Just out of interest, if it is ACTUALLY blocked, would clearing the codes also unblock it, or do you need to manually unblock first AND then clear the codes?
Sent from my G8141 using Tapatalk
Discussion Starter · #5 · (Edited)
It took me some time and effort to be able to respond with adequate information.
@fwd:
The manual reset suggestion failed
I don't have an answer to your question: just out of interest - - -
@64 SPLIT:
removing codes didn't help. And my battery is charged.
So thanks for your input
OBD Codes:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6E-Ctrl Head Roof -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Automotive tire Automotive lighting Bumper Automotive exterior Sports gear
The Can Gateway malfunction would be of concern to me - does this have any specific code against it? VCDS will allow you to scan it properly - some generic OBD scanners aren't able to properluy interrogate to provide full info/scan results.
Is it This what you had in mind?
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 0230
Coding: 042200
Shop #: WSC 02734 790 00000
VCID: 70EF65C7A3A31A0F32-8024
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 298083 km
Time Indication: 0
Date: 2016.07.25
Time: 11:36:31
Discussion Starter · #8 ·
And oh yes! some preliminary information.
The T5 comes from Sweden (this maps recorded temperatures of -40°C)
At around 68,000 km, the automatic transmission was replaced under warranty and later at approximately 165,000 km, the entire engine was also replaced.
I was not (yet) aware of problems with this type of engine.
It was only after a defective radar in the bumper that I heard from Denis Veldt from Castricum, Holland (link: Dennis Veldt – Garage & Speedshop Black8) what was going on.
As soon as he looked at the license plate form, he recognized the engine code and said "You have a problem".
He advised me to contact TSC de Betuwe b.v. in the Netherlands too.
For more info in Dutch, link: https://techservicecenter.nl/olieeconomie-volkswagen-tdi-biturbo-t5-t6/)
