New single din stereo installed. It's an ISO plug jobbie and from what I can see all the wiring and plugs are original so nothing swapped around by previous owners.
So the stereo won't switch on unless the engine has been started and then turned off (with key left in the ignition. Switches off when you remove the key).
The stereo works fine on the scenario above (radio, blue tooth etc.). The problem is when I start the engine the stereo just keeps restarting so can't have any music while driving.
I read some posts on here which make me think that is something to do with the ignition switch. But before rushing out and creating more problems wanted to check if it could be old ISO plug wirings Vs new Stereo wirings.
Can anyone help?
Attached a couple of pics of the iso plug
Can anyone help?
