Been a member a while, but i have finally managed to get hold of a 2003 caravelle 2.5TDI 88bhp LWB.
I was hoping to get a good condition low(ish) mileage one, but i ended up with one that needs a bit more work than intended.
It has 250K miles (i know - they go on forever). needs a bit of attention to the suspension/steering, few knocks from the front.
Couple of gremlins in the interior, passenger electric window is faulty, trim is a bit tatty in places, and it is filthy so a good clean is required.
Plans is to leave it as a caravelle, but maybe upgrade the seats. would like a T5 setup of 2 plus 2 and have nice seats. i generally drive a couple of times a year to Italy, and i hope to start to carry my scooters, have a couple of old vespas, which are nice to pootle around on in the area. So plenty of space for those in the back and the family too.
Need to look into rear suspension to see whether it can cope with that weight. i'm thinking it will as the bikes aren't that heavy and i guess the caravelle has similar capacity to the panel vans.
will post pics up soon
Full of Cr*p....
"Plans is to leave it as a caravelle, but maybe upgrade the seats. would like a T5 setup of 2 plus 2 and have nice seats. i generally drive a couple of times a year to Italy, and i hope to start to carry my scooters, have a couple of old vespas, which are nice to pootle around on in the area. So plenty of space for those in the back and the family too."
I have T5 seats in the rear of my T4....BUT!
You need a floor thickness of at least 20mm to route out the fixings for them.
AND, use some metal angle underneath for strength.
I have an option for a twin or a triple in the centre....
Van was converted from disabled vehicle when I got it.
Twin in the center, triple at the rear.
Didn't need all those seats, so moved the mountings to allow EITHER the twin central, OR the triple.
Triple has never been out of may garage, and will be going to the tip next year.
Twin is used 99% as the "dog's seat"...LOL:
Strange thing is....the "twin" has WIDER mounting slots than the "triple"....BUT, the triple does need 2 people to move it in or out of the van!! :eek:
STD T4 seat belt mounts are in the correct place for the twin or the triple.
Triple T5 has a 3 point belt in the middle, twin has it's own built in for the "inner" seat.
Edit:
Just been out and measured.......
Mine, SWB, but between the back of the "central" seats (as mounted to allow seat belts to work), there is 44" between the back of the seat and the tailgate.
I guess you get an extra 10" or so in the LWB, but will your bikes fit in there?
Maybe at an angle, but make sure you fit some straps to hold them secure.
Gaz
If you need pics, PM me with email addy.
Gaz
