Hi to all just got me a K reg 1992 1.9d T4 to convert to a camper and I'm in need of a instrument cluster as temp gauge not working. Please let me know if I've posted in the wrong area and point me in the right direction to post a wanted or if you have one let me know. Thanks in advance Mick.
Hi thanks for the reply, I've only just purchased the T4 and someone in the past had painted the gauge needles and the temp needle was stuck on the bottom pin from when the paint dried. I started with the process of elimination and changed the temp sensor (no change) I then stripped the instrument cluster out and found this problem in deeper investigation the little copper coil inside the gauge was burned out and needs replacing.
Ah , right , well you,ve done the right things , Maybe someone will come along with a fix for that , too ..?? Neither of my fuel/temp have worked for a couple years , if its any consolation . ! I just live with the intermittent times ..!!
