Hi people just bought a t5 a few weeks ago and love it just wondering it’s losing coolant not a lot but drives spot on been like that for over a year so don’t think it the head had a mechanic look at says keep a eye on it just in case looking for a good garage north Tyneside to solve the problem as don’t won’t to be ripped off thanks again folks
Check
Metal coolant pipe which runs across front and up gearbox side , plastic coolant flange above gearbox , expansion tank and cap , oil cooler on front of block , and of course radiator and all hoses and joints
Thanks stuartt I have just replaced the coolant Bottle and ordered the lid arrived today and changed it and that seems to have sorted the problem zero pressure after running the van and letting it Cool down so fingers crossed it has solved the problem thanks again
Welcome aboard, fingers crossed you've resolved the issue (y)
Discussion Starter #8
Thanks pduk Yeah hopefully it has solved the problem will check in the morning to see if the water has moved
