I bought a converted T5 (2011 LWB TDi 102) and I'm gradually finding out some things for a snagging list. One of which are the wing mirrors. They both adjust electrically but neither seem to heat up which I only found out yesterday when the temp had been below zero.
Does this mean that the elements in the mirror are both duff, or is there a fuse that may have blown or could the switch in the driver's door be duff?
Also on the snagging list is the front cigarette lighter socket.
If I need to get replacement mirrors are there any recommendations? I will be contacting the dealer but good to have an understanding of what the proper solution will be
depends if the glass on there is heated - pry it off and you'll see 2 connectors on the back if they are heated.
check if there's 12V at the wires when the switch is on
could also hook 12V up to the mirror itself to see if the heating element is working ok
