hi guys im new to the t4 scene but had a few golfs before plus quite good at amature mechanics!lol
i bought a 2.5tdi 51 plate engine is fine but think the clutch is riding high. got home the other day pulled up and stopped took the van out of gear (put in neutral) when released the clutch pedal there was a large knocking noise so depressed the cluth pedal and it dissapeared! any ideas? also does anyone know how much a full service would cost? also if anyone knows how good MAD-WORKSHOP in bristol are as there are just round the corner from me any help much appreciated!:*
It can be the releasing bearing on the clutch. It will expensive if it is the case, because in order to replace it you will need to remove the engine and gearbox. While you have everything apart it makes sense to replace also the clutch.
João
hi found out what the problem is its the thrust bearing so banged in a new heavy duty clutch plus all other parts! only £350 and done by a top bloke! T:
