I have a T5.1 which came with the basic RCD 210. I have a RCD 510 DAB in my car and have found it to be very good. I have therefore purchased one for my T5 off Ebay - advertised as working 100%. I tried to fit it earlier (plugging in the aerial / main cable) but got no radio reception. I was only trying FM / AM as I have yet to get a DAB aerial. I have put the RCD 210 back in and it works fine! Can anyone help - is it because I haven't plugged in the DAB aerial? Also can anyone recommend a good DAB aerial - is it best to got for a VW one?
I would also like to add an ipod / USB connection. Any advice on this would also be very welcome.
Go for genuine one and as for iPod kit go for dension gateway 100
or if you want iPod, b/tooth, USB then go for dension gateway five
as for signal I'm unsure what it could be but doubt it would be because
you've not got the dab antenna but that may possibly give you the dab
side of the radio but this can be tested by putting an small Allen key (4mm)
in the end whilst holding the Allen key you should get a signal
