had a slight prang recently witch seems to have conked my reverse into outer space, the forward 5 are all fine work and go in with no problem, but reverse just wont select, seems like there's something stopping it, does any one have any ideas what it is? or how to solve it?
or is my gear box knakerd and needs replacing?
not really had a look yet as weathers been a bit ruff, so not sure if the linkages are all OK, but if some one can give me a place to start im all Therese, than allot in advance
oz
dont know how hard your shunt was. seen this before when the engine had moved and you couldnt select all gears. the actual engine mounts were damaged. I would say you need to get it up on ramps and have a good look round to check everythig is ok
if it was all working before you may be lucky and find its something simple .good luck
