1 - 17 of 17 Posts
Hi all. Just trying to confirm if mine has a glow plug relay? If so what number and where is it fitted? Van won't start in the cold today and late for work/not going in
Help please
Help please
In the fuse box down your right hand side it might be the bigger black one with 102 printed on the top ! Mine went once so I took it out and gave a little tap and started allso there's a little black box above the passenger head light fixed to the front cross member with 2 fuses inside good luck T:
Thanks. I'll check once light. I'm down an old road with no lights in the middle of no where
As above check the relay and the fuse on inner wing drivers side. Be worth replacing the glow plugs as soon as too
Thats if Eurocarparts got correct one. Last time I went in they said my number plate came up weird
Discussion Starter #10
Glow plug light on dash goes out if relay 102 is taken off, so assume ok?
Where exactly are the other 2 fuses by the passenger lights?
mine has a black fuse cover on the trim bit of the inner drivers wing, open bonnet look at that side behind air box, check that fuse is good and tight T:
Discussion Starter #13
I thought it was meant to be above nearside light?
not sure, there are 2 big fuse blocks above the light too, but i always made sure the fuse on driers side was ok :*
Discussion Starter #15
Tea 1st then I'll walk to sainsbury and see if got easystart in garage. otherwise Im stuffed
Discussion Starter #16
Well sainsbury sucks big time. Not even engine oil
I still not clear as what FUSES I am looking at. Nothing by lights and no idea about ones by the air filter
I must be stupid as I cant even suss out how that comes off haha
Discussion Starter #17
Still not sure about the fuses BUT it runs, after a bit of Easy Start
After a cold walk to Sainsbury..garage is useless, shop even more so ( no easy start let alone anything! )
Walk back home with hump
Cycle, yes I said cycle ( 1st time in years ) to a BP garage/M&S..none either ( lovely grapes though )
Then I remember a little car accessory shop further up the road
YAY for little independent shops.
Cycle/walk back ( tyres low and I'm fat and old ) and spray a little in there, Pop!!! Starts straight away. Might also be that its warmer
I should be finishing work at 2.25. Bit late to go in now!
1 - 17 of 17 Posts
