I'm fairly new to the forum and have just tried to replace my Temp sensor in my 1999 T4 1.9TD. After much research I concluded that I needed 059919501A Green 4 Pin, I came to change it today and on removal of the old one it appears it to be brown not green and has a part number of 074919501. I have tried to search other posts but cant find confirmation if I can replace it with the Green one but with no luck.
Can someone please confirm if I can use 059919501A Green 4 Pin as a replacement for the Brown 4 Pin 074919501
Thanks for your help
Phil
Discussion Starter #2
After speaking with my local VW today my '99 1.9td engine has to use the Brown 4 Pin 074919501 which is unfortunate as it costs £32 compared to the £6 Green Sensor!
Phil
I think there is 2 temp sensors also. One on the side of block, blue i think. My temp light flashes since i had it but still not fixed itI:
Some good Info you have put up there though fella. Thanks for the heads up on whats what on the front oneT:
