Hey folks
my 2001 1.9 t4 was not starting checked glow plugs and all four needed replacing.
since then sometimes she will not start. Sometimes when driving and engine hot it wont start and sometimes when cold.
im thinking its either battery or altenator??
Any advice help would be much appreciated
Hi Mate
If is it turning over but not starting it
Could be the Thermo valve on the Fuel Filter
letting air back into the fuel pump.
check for bubbles in the fuel lines
Mike
Checked battery and altenator and both give the right voltage readings... il look for bubbles n fuel linea next... is there a way of checking weather starter motor is ok or not?
