went and got some new bulbs for my numberplate and still they are not working. is there a fuse that could of blow and if so which one is it. cheers
tinbottom
More likely to be dodgy connectors. Had this problem on a few. Take out the handle and you will be able to see where the connectors have fallen out of the back. Should have said yesterday when you were here, we could have had a look.
also check the the terminals that the light fits into are showing i had this problem and had to pull them down a bit with some long nose plyers so they made contact with the end of the bulb
Agree. the fitting of the lamp holder into the van is a bit trickly. Make sure that you have enough pre-load on the connections. Also make sure that the connections are clean. I changed my bulbs for LEDs the other day and the connectors were all quite badly corroded.
http://berthathebus.blogspot.com
I'm having the same problem, New bulbs fitted but have discovered there is no live to the wire...
Is there a seperate fuse?
the fuse is on the top line of fuses round the middle(cant remember which 1 now) changed mine at weekend,had to sand the connections inside both holders aswell before they would work
