Still cant chase off this leak and after doing the thermostat amongst some pro-active refurb work, I think I have located the leak's....
Coolant is pooling under the sump, which looks to be over the power steering pump too, which I assumed was running off the thermostat pipe.
I think coolant is leaking from somewhere on the left hand side of the engine, then running down onto the wheels/pulleys at the bottom and flicking it all over the power steering pump. This is a super slow leak, i.e. about 1-3 big drops over say a week. I currently have the the van on jacks as overhauling the brakes as we speak......
I have tried to look at the diagrams on line and work out where is what, but could it be the water pump on the left simply leaking or are their o-rings on the lower pulleys or anything that could be leaking from the engine itself as it were?
One for the garage I suspect......any pointers, thanks.....
