Has anyone recently purchased and fitted a OEM Caravelle type front fog light kit? I'm looking for a good quality kit to retro fit to my 888 Special. I've ordered a pre cut bumper but wasnt sure if I need extra brackets and switch. Also would like to switch front and rear independently, I believe a Mk3 golf headlight switch is same as Caravelle but need that confirming. Any info appreciated..馃憤
Along with the lights you will need the connector plugs, relay to plug in to the relay board position 10, the lamp supports that hold the lights into the bumper and the switch. Looking there are may kits available on ebay but can't recommend one etc. I think it is the Mk4 switch, which has the double pull, one for rear and second for front but someone else will confirm fitting. The whole light switch comes out of the dash and it can be changed over for the replacement switch.
