previously known as passattdi
Hi All,
My swb T5 van was converted by T4 World, I've since fitted a rear window on the rear panel on the passengers side. I've contacted them but no reply so far. Does anyone know what the dark grey carpet they use is?
The carpet is around the edges and enough to carpet up to the edge of the new window trim. However, I've not got any to go along the bottom edge of the window. I think its the dark smoky grey that MVM uses, I need an offcut to go along the bottom edge of the window, enough to go from the window trim to behind the new panel I've got make.
Its probably about 6" wide and long enough to cover the lower edge of the window.
Let me know what you've got, its going to be behind a panel so it will mostly be hidden but I want it to match as much as I can.
Red5
