i have 19s on at the mo with a 35 offset, im gonna go to 18s, but want a really wide back set!! my back wheels sit inside the arch at the moment, so.....
can i use a wider wheel with a bigger offset to get the wheel to fit in!!??
if i had a 50 offset and a 10j wheel would that work, or would it be better to get a 35 offset as this makes my 8j sit inside??
the fronts at the moment sit slightly too far out so im gonna go to a 45 offset there, and have an 8j.
any advice would be great:ILU:
if your going to use 10'' on the rear then 50mm et is to high as the higher the et the more the rims inside the arch.i run 18x10's with a et of 35 and they just clear the inner body/arch
by a couple of mm.but stick out the arch about 10mm and look good
