Oh No! Another Horn thread! - Now With Fix
Hi all
So far I read maybe 18 threads on the subject but not one has this symptom.
Today I pushed the horn to let a pheasant know I was coming and nothing..
It had worked just the other day when I had to use it to save some backing into me in a supermarket car park.
So far I've taken the plug off and checked for voltage, this is where its odd, No ignition, no volts.
When I turn the ignition on i see a strange pulsing effect on the multimeter, between 3 numbers to fast to read. Operating the horn button has no effect, also fuse 13 is intact.
After about thread 7 I noticed a consistency so off came that steering wheel and sure enough black grease, dirty pickups.
I cleaned both items and refitted, still nothing.
I'm going to check the loom in the morning near the actual plug and also try the horn on a separate small battery.
Any ideas peeps?
Thanks in advance.
*edit*
I've also tested the steering wheel horn mechanism for continuity when operated and its fine.
I can't hear any relay noise when the horn is operated but then I only have a single wimpy meep meep so i'm not sure I should have one.
Hi all
Any ideas peeps?
Thanks in advance.
*edit*
