I have just changed the oil and filter on my 1997 1.9td. The square housing section at the top that the filter screws up to has started to twist with the filter. I have managed to get the filter undone and replaced but concerned i'm going to have issues next service. Managed to tighten the square housing as much as possible but it is weeping very slightly. Has anyone else had this problem? Am i going to have to replace the whole filter housing that joins the block, or can it be repaired?:confused:
When you whip the filter off, Look up at the threaded shafter and there is a large thin bolt that holds the 'Square housing section' in place - Tighten that up and Job Jobbed T:
The 'Square housing section' is the oil to water cooler :ILU:
Thanks guys. Spoke to TPS and the seal required was £3 + vat. Thats my Saturday sorted then! Shame i changed the oil as i'm guessing i'm gonna lose some of the new stuff changing the seal.
