1 - 9 of 9 Posts
ok iv just change my clocks because my fuel gauge wasnt working my new clocks have a clock instead of revs, everything works but since doing this my oil light and a bleeping has started,it got enough oil in it does anyone have any ideas on this one thanks
Usually if you change parts or have work done at garage they vagcom it to reset the ECU i believe-If you un-plug the maf sensor for instance with say the ignition on-this would show up on the vagcom-it plugs in under the steering wheel column like a laptop and resets the parameters of the ecu-ecu shows up all faults and by changing clocks may need certain things ie oil light resetting!
I know f all but it's somewhere along these lines-if not this maybe a wire or bad connection/broken wire?
hope you get what i mean I:
hi yes i understand thanks for that so a vagcom is the computor you plug in to reset or diagnose problems, where could i get it reset, do i just take it to my local vw garage for this or is there somewhere else, sorry for all the questions thanks again
No worries with questions fella :)
You best find someone on here in your area that may be able to vagcom for you-my mate does my checks usually for free-garages although good can charge highly just to plug these in-got quoted £40 + vat before they even started work :eek:
First as stated you need to find cause of your problem-Vagcoms just a starting point I:
hope this helps-someone will/should help on this forum ;)
Discussion Starter #8
thanks a million for that pal cant tell you how much that has helped, i have one more question for you, how did you find that thread, im new on hear and i cant find out how to search for threads again thanks so so much for your time
1 - 9 of 9 Posts
