Over the last 3 years I have tried everything suggested to stop my oil pressure buzzer going off at 1800 rpm when warm... the van is at 105,000 miles and is sweet with no knocking...
I've had pressure sensors, level sensors, a dashboard and more...
My concern was the oil pump was either blocked or coming loose... I was told if it was coming loose that there would be a leak of oil... there wasnt...
It has slowly got more common and annoying...
"We" took it apart at the weekend... (I watched)
That big round disc is loose...
I can only assume it shouldnt be and is causing the problem... :ILU:
So now its belts off, oil pump off etc... as you cant do the screws up as with the crank in the way!
Anyone else experienced this?
