Looking for some help with the oil pressure light on my van, its a 1.9 td. The buzzer and light only come on under 2000 rmp and it never sounds or flashes above these revs. I've read other posts describing a similar problem where the vans have 2 sensors, one for low revs and one for high. However I can't find any posts that describe the same problem where the sensor is only on the oil filter housing.
Does anyone think that this single sensor would be able to differentiate between faults above and below 2000 revs? Or is it more likely that the pattern I've found is only a conicidence?!?
Any help would be appreciated as we're supposed to be going away next weekend and the beeping is driving me crazy!
Maggsy
