Hoe do you change the oil pump in the T4 2.5 tdi AJT engine?
Do you have to remove the engine?
Thanks in advance guys.
Engine doesn't need to come out. You need to remove the auxillary belt then timing belt covers and idler pulleys and timing belt and crank pulley then you can remove the oil pump.
Youl need to remove the pulleys and stuff on the crank, the highlighted part here is the drive cog for the pump.
Then all this stuff has to come out. Which also means the sump must come off.
