2007 1.9 TDI LWB Bus T5 BRS engine 150000 miles
After a long winter and the van being a bit of a project. All the bling is here. I now re looked at the engine after oil light flashing and sensors changed and still the same. The new cam Is just getting a bit noisy so bought a oil pressure gauge and Tee it of the oil pressure switch and start the van 0 Oil pressure ZERO ! never ever in all my years have I had a total pump failure so next job sump off to have a look and remove no 4 big end and no 4 con rod to do an inspection. I hope it will be ok but new pump and see what happens if its ok. No noise from the engine no smoke or knocking. Guys if you have the oil light flashing spend £40 and fit a caperlary oil pressure gauge.
