Hi
I have just had a unfortunate problem by "stupidly" not checking the vacuum pump rod size when fitting a new (Chinese) pump that according to their site and compatibility tool said it was ok - I thought it needed a bit of pushing to get on but just thought oh this is a better fit!!! OK stop laughing now ha ha - the pump worked well for a hundred miles then disintegrated - lost brakes and lots of oil but have saved the cam and the engine so all kind of good.
OK so my question is - getting a pump to fit a 71mm rod seems impossible so is it OK to simple fit the later type pump and then a 67.5mm rod? Is there any reason why this would not work?
Angelo
Angelo
