1 - 11 of 11 Posts
Hi Lowriders,
Im just about to purchase some calibra springs from an online breaker and they have been removed from a calibra v6. I went for these springs over the 2.0L ones because i thought that they would be a little bit more of a heavy dutier spring.
What i do know is that they are standard v6 calibra springs but nothing else apart from that, am i good to go or do i need to check any part numbers ?
Peace Road huggers :ILU::D:D
From what i've read i'd say your good to go, and from what i recall the v6 are much the same as the regular 2 litre.
year there the same pal as long as its not the 4x4 one witch it wont be if its just the v6!!!
you do know you have to trim the pig tails off dont you???
What do you mean dude ?I:
If you use these springs on a t4 bus they lower it 120mm apparently. H:
Then all i gotta do is buy my GAZ Shocks and then its the dreaded respray time :eek:
If i did that to my Van the speed bumps around wrexham would kill me and the van. Good luck though, pics when done.
Guy
1 - 11 of 11 Posts
