1 - 9 of 9 Posts
The orange oil light wont go off! I've changed the oil, checked the pressure, changed the sensor, checked the wiring as far as I can but still wont go off. It comes on and sounds an allarm a few seconds after switching on the ignition, before engine in other words.
any ideas? help please!?!?!
does this apply if the orange oil light only flashes about four times when the ignition is switched on then does not come on again *<:)>
thanks max1956bike and trism286 - same solution so it must be that - tried openin and closing bonnet and fiddling with switch - will try joining wires when it dried up a bit...
climberian - no, orange light just goes on and stays on (after sounding an alarm for a second) - i'm hoping it is the bonnet switch....
No there are two pressure sensors, one on the bottom of the sump, and another somewhere i cant remember, if it flashes 3 times when you turn the igniition on before starting the engine one of the sensors is broken.
Mine does it, i checked on vcds and it shows the sump one is faulty, i'll get it changed at somepoint ...they're about £60
Last time I bought one they were more like £90
:eek:
Not to sure if this is any good for you but to reset my oil light I had to disconnect the battery for a few seconds then connect again. T:
1 - 9 of 9 Posts
