Just about to install my windows in my T5. However the gap between the inner and outer shell is wide enough to put my finger down it. Is there a method to bring them closer together to fit the trim neatly?
Yes, you'll need to remove the bonding by trimming it out with a sharp knife. It will take a few passes, but once this has gone the two surfaces will come together (add some new bonding before you pinch together with the trim so it sticks together in the new closed position). Follow the instructions on the Kiravans site here http://www.kiravans.co.uk/step-by-step-window-fitting-guide-vw-t5 - and you won't go wrong T:
