Hello, can i upgrade and control the webasto heater in my T5 2012?
I have no parking heater funktion now, it just starts when i´m driving.
I have been looking at the over head panel? Will it work?
Se pictures, the info sticker for the heater and the over head panel.
175458
175459
The upgrade let's you control the heater from a Webasto Controller, which can be a timer display, or even a remote or receiver with SIM card and app.
So it's just time based.
I actually don't know for your Climatronic model and if you can set a certain temperature from the van's own heater control..
With my Climatic I just set the temperature to HIGH and than choose fan blower speed 1 or 2.
3 or 4 works too but that will drain the battery pulling 10-20 Amps!
Hi...
I've got a 2012 Caravelle, with a Webasto Top C Coolant Heater, with no controls at all!!
I have no overhead control panel, can I upgrade? any improvement would be better than the option I have at the moment.
Would the Webasto overhead panel control wiring be in situ, or would that be another issue, installing the wiring loom?
Also, does the vehicle 'Canbus', require updating / upgrading, after any additions to the operation of the Webasto Top C unit?
Thank you.
Regards.
