Whilst installing passenger side Dash and door speakers i have obviously caught a wire behind the passenger airbag... The warning light is on the Dash it comes on after a while once it has checked the system and found a fault....
Anyone with experience of Airbag passenger trouble / know of what wire i have pulled. I know from changing the indecator stick to a CC unit the wheel airbag has a very light weight wire, is there the same on the passenger side that i have broken???
Any ideas on the part / wire i need to check or ultimatly replace.
Bert
Fault Code
Address 15: Airbags
Controller: 1J0 909 603 BK
Component: AIRBAG VW3 - V04
Coding: 16971
Shop #: WSC 02743
1 Fault Found:
00589 - Airbag Igniter 1: Passenger Side (N131)
32-00 - Resistance too High
You might have just pulled the plug out a bit from the airbag and not damaged anything.
Then all you'll need is a finger to push it back in.
If your gonna have a probe around would advise you disconnect the battery for 30mins.
