Hey guys,
I have the following problem in my '93 T4. I can't get the passenger door locked. Opening and closing works fine, but when I press the locking pin, it just pops back up. Same with the key, i lock it the pin goes down, i remove the key and there it comes pops back up!
Anyone got a clue?
Discussion Starter · #2 ·
Okay, I removed the central locking servo from the door, it can lock now (by hand). I got it open and the inside is pretty corroded.
New servo required I think Fella!
Or you could try cleaning it up T:
I would try a cleaning first, and would pay special attention to contacts. Try Contacts cleaner and also check the electrical inside the door. It could be a simple electrical problem, most usual a faulty ground.
Meh the motor in the servo is pretty dead, it also has this weird talk-like powder on it. I tried putting 12v on it but it won't budge. Does anyone know where I can get a cheap converter since the servo is a pre 199-something black one.
