Hi everyone,
I have an issue with the passenger side door lock on my 1999 T4 800 special and was wondering if you could help. The key is able to 'lock and unlock' the door from the outside however the door only opens around 2cm before stopping - I think the mechanism latch that holds the door to the frame of the car isn't opening all the way.
I am unable to open the door at all because it is locked in position, therefor I am unable to take the door card off. I can however can bend it back at the top by the window but access to the mechanism is very very tight. Once the door can eventually be opened I'm aware that the door lock mechanism etc can be replaced however am stuck in that the door wont open. As far as I'm aware, the catch in the door lock mechanism isn't full opening when the door handles are used, so is remaining attached to the metal on the car's frame.
Im at a loose end as all the information online to solve similar problems requires you to firstly open the door to access the screws holding the door handle, door card removal and eventual lock replacement!!
Hopefully someone can help as I really don't want to have to drill or cut out the locks and ruin my T4!
Thank you all :ILU:
Thank you all :ILU:
