Hi, just bought an 04 Caravelle 2.5 130. The passenger side electric window has stopped working and is stuck about 10 mm open from the top. Also, the electric mirror movement control has stopped on the same side although the drivers one works on the same switch so I'm guessing its not that.
I was hoping that they were linked on the same fuse but I can't make head nor tail of the fuse cards and I'm not even sure the window is on a fuse??
So, has anyone got any ideas? I'd like the window to work at the very least!
Thanks for any help. :ILU:
Could be broken wires in the body to door cabling. Easy to fix, although quite time consuming if you opt to change the loom...
i have the same problem after my friend left the passanger door open and it rained. iv just bought a second hand window motor but it still doesnt work, dont know if thats because of the motor being duff or if its something else. any ideas?
