1 - 14 of 14 Posts
Banned
ahh cheers guys looked like i fudged up lol...
i mean the wheels are already et33 without the 25mm adapters, so what the finel et going to be with the 25mm adapters and then what size adapter would i need if i wanred et15
cheers again
i'm thinking about using adapters on another car and cos the maths won't work I now reckon getting the hubs/disks drilled & tapped would work a whole lot better - might be worth considering...you could bolt your wheels straight on :*
Its about time I showed up
If i've understood you right the wheels will be ET 8 with the 25mm adaptor bud :ILU:
So if you want ET 15 your gonna need a 32mm plate instead of the 25mm yes?! T:
1 - 14 of 14 Posts
