Hello folks, pdc on the rear of my t5.1 is acting up, had the codes read on a solus and revealed the right outer sensor was faulty. Ordered a new one still the same. Are there any re occurring things that should be checked or common problems ? I’ve inspected the wiring as best I can and there’s nothing obvious I can see and I’ve cleaned the terminals within the plug.
cheers
I was going to say check the plug, mine has an intermittent fault that rears it’s ugly head when it’s been pissing down a lot - like recently🌨. I replaced the sensor 2nd from right and it worked ok for a while ( the original sensor was full of water)
Thanks for that I’ll check all the plugs just for good measure
So checked everything out........... the fault for the right hand sensor had been caused by me unplugging it ! Cleared the codes and rested everything again, no faults ! Still the same in operation !.......... the fault was anyone like to guess ? The tow ball cover............. hours of head scratching ! And it was that ffs 🤣
