I have a bust lug on my jack cover on my T5 (7H5.868.433.A)
I have spoken to various owners who say this is a common problem but no one seems to have a decent fix? I could buy another (£40 second hand) but it looks like the same issue would happen again.
I have checked on 'thingyverse' as it looks ripe for a custom clip you glue into place - but I couldn't find anything. My Velcro solution didnt work.
191424
191423
Anyone have a decent fix?
I'm new to T5 ownership and am really surprised by the amount of design 'niggles' that have not been sorted after all this time being made?!
Discussion Starter · #2 ·
This is the only 'solution' I can find but seems a bit of a bodge and potential to cause more issues if the nail gets stuck
I have exactly the same issue - 11 plate Caravelle arrived last week and the cover was already flopping around in the boot. I was going to try stick-on velcro patches but sceptical about getting a good fix on old plastic. Failing that I think I still have some rare-earth magnets in the shed, although likely to still find it hard to get them to stick satisfactorily.
#da_murphster, what did you mean when you said "This is the only 'solution'..."? Were you referring to velcro or some other solution which you intended to link to?
We've also got a few other small bits of trim missing, a broken drivers door lower hinge, a temperamental sliding door handle which doesn't always make good contact with the switch for the solenoid valve... like you say, surprising the number of niggles!
T4 2.5 TDi 2003 SWB
Do you still have part of the plastic clip, or the clip itself? if you don't, it doesn't really matter.
Years ago I repaired a broken plastic clip on a battery compartment cover on a radio, using 'Bicarbonate of soda & Super glue'.
Amazingly strong, much stronger than Superglue on it's own. If you don't have the broken clip you can simply 'make' a new one and file it down to shape.
I just had a look on YouTube, there's loads of 'HowTos' on there.
Even if you had a replacement part 3D printed, chances are, bonding the two together would be problematic, the 3D printed part ( PLA ) Polylactic plastic, probably wouldn't bond to the ABS OEM jack cover. Bonding two different types of plastics requires special adhesives, somehow, Baking soda causes a reaction with the CA glue, almost like a Catalyst, making very hard.
It's time consuming, but certainly worth the effort.
TURK
